Beelink GTi14 Question Summary
Q: Does GTi Ultra support external graphics cards?
A: Hello, GTi Ultra supports external graphics cards, but it needs to be paired with our graphics card expansion dock, and the graphics card dock station has a 600W independent power supply.
Q: Why does the GTi Ultra speaker have no bass?
A: Hello, the built-in speaker of GTi Ultra optimizes the human voice, highlights the mid-high frequency band, and makes the sound clearer and more prominent.
Q: Why can’t GTi Ultra directly use the power supply of the expansion dock to power the PC?
A: The PC and the expansion dock are two independent products. Although they can be used together, there are also users who buy them separately, so they need to be powered independently.
Q: What is the TDP of GTi Ultra?
A: The maximum stable power at full load is 65W.
Q: In addition to external graphics cards, can the graphics card dock also connect other PCIE devices?
A: The PCIE interface expanded by the graphics card dock is a standard interface, supporting standard PCIE devices such as sound cards, capture cards, network cards, and expansion cards.
Q: Is there any loss when connecting an external expansion device to the 8X interface? How much?
A: There is basically no loss when using a 4080 graphics card or below.
Q: How to select the audio output and input source?
A: Settings - System - Sound, select speakers and microphones.
Q: Will the graphics card dock block the bottom air intake and speaker sound?
A: There is a certain distance between the host and the graphics card, which will not block the air intake and sound.
Q: Can AI voice interaction use voice commands to command computer operations like Xiaoai classmate?
A: We provide a voice interaction platform that can use any AI large model that supports voice interaction to effectively help you solve problems.
Q: Can the SD card used for the camera be connected?
A: The SD card interface supports high-speed camera SD cards and TF cards inserted into the card holder, with a maximum speed of up to 312MB/s.
Q: Why is there no AMD processor?
A: Because Intel processors are optimized and more compatible with more software, provide better productivity, and can be connected to external graphics cards without using the core graphics of Intel processors.
Q: What is the external transmission speed of the graphics expansion dock?
A: The transmission speed of the graphics dock is PCIE 4.0 ×8, and there is almost no loss for external graphics cards.
Q: What is the power of the built-in power supply of the expansion dock?
A: The built-in power supply of the graphics dock is 600W.
Q: What other functions does the expansion dock have besides external graphics cards?
A: The graphics dock has a built-in 600W power supply, supports M.2 hard disk or Wi-Fi network card expansion, only one of the two can be selected, and there is another USB interface.
Q: Can GTi Ultra use a third-party graphics expansion dock?
A: No, the GTi Ultra graphics dock is customized and is not compatible with third-party expansion docks.
Q: Does GTi Ultra support Thunderbolt graphics expansion docks?
A: Yes, GTi Ultra has a Thunderbolt 40G interface and supports external Thunderbolt graphics expansion docks.
17.Q: The minimum standby power of GTi Ultra is 28W. Is this normal?
A: This is normal power, because the built-in power supply itself, built-in speakers, fingerprint recognition module, USB HUB, etc. all have certain power consumption, and the Intel Ultra processor is very powerful and will also have higher power consumption, so 28W is within the normal power range.
- Q:The performance drop sinificantly when connecting to the EX docking station, what should we do ?
A: If your PC connected to the EGPU, the performance goes down,and there are stutters in games, please go to device manager and disable integrated graphic. Also, please go to 【BIOS】-【Advanced】-【System Agent(SA)Configuration】-【Graphics Configuration】-Set【Primary Display】to【IGFX】-press F4 to save and exit.
19: What power connector should I use for my graphic card?
A:【Notice】— The docking station features two 8-pin power connectors. If your graphics card requires 3× 8-pin connectors, you may need an 8-pin to dual 8-pin adapter cable. If your graphics card uses a 16pin port, you may need a 2×8pin to 16pin adapter cable.
You can learn more at https://buildin.ai/lizong/share/3550479f-6d3b-4cc9-bc40-892722c1e0b6
