tzsolt Hi there,
Here is the driver https://url.bee-link.cn/jpUx or https://mega.nz/file/W6JmWIDS#2VE4ZZ6iLz3sB_Vfpj4driqZsdE0njq51zPes6paqaI
tzsolt Hi there,
RobD Hi there,
Here is the driver https://mega.nz/folder/agkDyYJR#IdBuES-SQi37XHEe37gTuA
cyterio Hi there,
RobD Here is the tutorial https://buildin.ai/lizong/share/50c2dee7-dcde-4707-97d8-dc7eac84a4eb
Can I download the Graphics Driver directly from Intel?
A customized computer manufacturer driver is installed on your computer. The Intel Driver & Support Assistant is not able to update the driver. Installing a generic Intel driver instead of the customized computer manufacturer driver may cause technical issues. Contact your computer manufacturer for the latest driver for your computer.
hi, can i have the drivers for sei14 please.
keen Hi there,
Here is the driver SEi14 https://mega.nz/file/H7wA0JBS#5f5lgrcutQdG-tZzMpdmUef2CXtRokeivU44VE16RX0 or https://url.bee-link.cn/BwPw
Hi, is there a changellog for the 2 new bios files for the Gti12 Modell ?
Hello, I’m trying to reinstall Windows 11 Pro on my Minis12Pro-A 16512SD0W64PRO-B/XB/M. S/N BN1004LG12730
beelinkusafw
Here is the image https://mega.nz/file/umxF1bbY#r5VtTGsz3yX1ESIaJU-W5bsHvi3_oihOD2iqqunPOJ4
Here is the picture tutorial https://mega.nz/file/KjZHyIqB#0EEVnG_1fWYCq_qL7GUYFGuD7nKqlV8FZWu78SVGXS4
Here is the Video tutorial https://mega.nz/file/rjw3DLjB#oCO056vM5R3bB2f1n9Kqj9aTF7eHDqGsmVghNekhsP4
If you need a key, please let us know.
Hello Beelink Team and Community,
I am reaching out to inquire if there is an available BIOS update for my Beelink SER5 PRO. Here are the current details of my device:
Model: Beelink SER5 PRO
Serial Number: Y58004LG80818
BIOS Version: SER5H508
Build Date and Time: 12/12/2023 14:34:10
I would appreciate any information or assistance regarding the latest BIOS version or any improvements available.
Thank you very much for your help!
Best regards,
i have just received my Beelink SER8 AMD Ryzen™ 7 8845HS and wanted to ask if there is a more up-to-date BIOS for it?
Product: SER8 AMD Ryzen 7 8845HS Mini PC
gY.3600834N10
SN:Y88454LF70695
Thx for your help,
Magiq1979
