Beelink CS-George Pritzl Hello there, Please press delete key as soon as you turn on the PC, so that you can go to BIOS. Please send us a picture of the Main page. We will check if you need to update the BIOS.
Pritzl I am hoping to get some resolution on this. If a bios upgrade to fix the loss of power recovery (s0) is not an option, then I need to move onto a different device. Please let me know if a bios upgrade will fix the issue.
salvo89 hi, after update bios with SEi-8279-8109条码为-A的BIOS_2024-05-10_1-19-02 , pc won’t recognize ssd and wont boot please help , thanks
Beelink CS-George salvo89 Hi there, Hello there, Please send us a picture of the purchase record and a picture of the SN on the bottom of the PC
salvo89 I canti find purchase record , SN Is 8279h1hg90470 Now BIOS wont start , White led turn on after 1 minut turn off and turn on again Now BIOS wont start , White led turn on after 1 minut turn off and turn on again
Beelink CS-George salvo89 could you please send us the whole numbers of SN as well as the numbers under 8279h1hg90470 ?
Beelink CS-George salvo89 Hi there, your SN doesn’t end with A, so the BIOS you flashed is wrong , the PC become brick. Please contact our support to send the item back for repair. Here is the email support-pc@bee-link.com
salvo89 Could you send me the right BIOS file ?( Better .rom) So i can flash manually on my own the rom on bios chip ,thank you
