- #1
Big problem with my SER8, it worked perfectly for 1 month and then it became a nightmare, it crashes at least once a day, my two screens turn white and I have to reboot the PC. I still have the same error in the Windows 11 log.
“The description for event ID 1035 in source amduw23g cannot be found. The component that triggered this event is not installed on the local computer or the installation is corrupted. You can install or repair the component on the local computer. The specified file cannot be found.”
I have already booted in safe mode, uninstalled the Radeon drivers, and reinstalled the original driver that was installed on the PC. I stopped the Windows updates, but nothing works; it continues to crash.
Unfortunately, I will have to send it back unless this error is known and Beelink finds a solution.
Thank you for your feedback.
Patrick!
Image description
