Beelink CS-Rose
Hi and thanks you for your answer.
① Both fans are spinning, I can hear them when the temperature reach 92°C but then it stays at this temperature, it barely goes down.
② I was using the standard plan with cpu/min 80% and cpu/max 99%. Would you recommend using the high performance mode ? Wouldn’t increasing both values to 99% result in more temperatures ?
③ I would prefer to not go that way but it sounds like I will not have the choice.
④ S/N : D58003IG60458 ; BIOS VERSION: 5800H506
I am currently using a monitor stand to enhance the airflow. Would you recommend removing the bottom plate?
Thanks you very much.
Regards.
