I have been trying to get the sound to work from my Mini S Pro via HDMI connected to a Samsung TV and cannot get anything. I have another mini computer from a different manufacturer and the sound works great with the same TV. There are no yellow exclamation marks on any devices in Device Manager. Here are the devices shown for Sound, video and game controllers:
HD Audio Driver for Display Audio
High Definition Audio Device
I have downloaded the drivers from Support section. File name MINIS-12-proDriver_2024_05_14_6-41-42.zip
That hasn’t seemed to help.
Any ideas would be appreciated. Thanks.
What is the operating system are you using?
Could you please try another monitor ?
a month later
same problem, will windows 10 fix the problem of intermittent sound disconnection?
    ivan33 Hi there,
    I suggest you to update the graphic driver .
    ivan33 try clicking the sound icon at bottom right,
    right next to the volume slider on the right side click that icon. “select a sound output”
    for output device make sure its selected. i had to change mine when i hooked it up the LG tv.
