clefkon I have a SER5 5560U [SER5-E-16512EJ0W64PRO-D] and wanted to update the BIOS and noted there appear to be 3 different zip files as below can you help me identify which one I should be using? FP655U504_Beelink.zip FP655U505_Beelink.zip FP655USER.508.zip
support10 clefkon Hello there, Is your machine the version with two HDMI ports? If so, then V505 is the latest BIOS version for your machine. I have sent the BIOS file to you, please check the PM. Have a nice day!
clefkon Yes it has 2 HDMI ports, thanks for the speedy response and confirming which version. All flashed with V505 and showing as updated and working. Thanks again!
support7 If you have any questions during the use of the machine, please feel free to contact us. Have a nice day!
