- #1
I decided to clean reinstall windows.
I could not find all the drivers from Beelink website.
I downloaded the large driver pack SEi14_2024-05-27_2-40-17.zip there are drivers missing from there.
For example intel avstream driver and intel txt.
There are many others that I had to manual search the internet using the hardware id and match drivers.
I also could not find updated Senary audio drivers anywhere with hardware id HDAUDIO\FUNC_01&VEN_14F1&DEV_5098&SUBSYS_14F1170E&REV_1001.
Beelink needs to start listing separate drivers and also update them continually.
Bios and firmware updates should be done within windows with an option to install using usb bootup.
Regular non technical users would not feel comfortable using the usb method.
Follow Lenovo’s support website as a template.
You can start to implement this with models that contain 13 and 14 gen CPUs.
At least with AMD models we can go to AMD website and they have a single tool to find and install all drivers.
