[unknown] Hi there,
Thanks for your sharing.
melonraba
1.Please make sure your WIFI signal is full.
Make sure that the distance between the PC and the router is less than 6 meters.
Please uninstall the wifi driver and then resatart the PC to see if it works.
Please right click the windows —setting -troubleshooting —other toubleshooters— internet—run , let the PC diagnose the problem and solve it automatically.
5.Please update the driver. Here is the driver source : https://dr.bee-link.cn/?dir= click the item model , then you can find the related driver.
Go to device manager , click the property of the Intel WiFi driver —advanced–choose property 802 ax, value also choose 802 ax.
Please clear the CMOS. Please turn off the PC , unplug the power supply, and put the pin in the pinhole and press it for about 10 seconds , restart the PC after ten minutes. Here is the tutorial https://mega.nz/file/XypwTISY#DVT0BsjOgiPkZ-drQaj88JH9Z7f7qpKGP2E3nMHW8ms
8.Please right click the windows–computer management–double click Services–①Wlan auto config–start the service, ②WWAN Auto config —start the service.
9.Please go to the windows terminal (admin) > type in : sfc /scannow > then wait until finished.
10.Please try this software [https://mega.nz/file/X7hGVZwb#1tA5wEJhxH8BDtKxeB5qS2ZiIEUByAVZoOnzhSf4-Pg] or [https://url.bee-link.cn/meE5]
- Right click windows –go to settings—network & internet—-Advanced network settings–network reset–reset now
