- #3
support1 As I wrote at the beginning of my post, the system already has the latest BIOS (V029 from 10/23/2024, you can click on the link to see the image you want)
Of course, I first used the latest AMD Auto-Detect and Install tool (release date 2024-12-05).
I also tested the drivers provided by Beelink, as described above.
Since that didn’t work, I tried ALL previous versions of the AMD chipset drivers back to version (3.08.17.735 Release Date 2021-08-23).
I also tried the drivers provided by Microsoft for the GPIO controller.
Through my tests it is clear beyond doubt that there is a problem with either the GPIO controller (ACPI\AMDI0030), its driver or a peripheral connected to the system through the GPIO controller.
