Hi,
I have been experiencing multiple problems with this machine. Repeated crashing for a multitude of reasons.
I did a fresh install of windows and re-loaded all the drivers from Beelink.
Still no resolve, it remains a completely unstable computer.
Bought it from Amazon on July 2022 and have reported the problems to Beelink in 6th December 2024.
I have since purchasing the unit found that it was supplied with hard (dry) thermal Paste and inadequate cooling for SSD.
I am very unhappy to have bought a relively expensive product and for it to fail in only 2 years and likely for the reasons above.
For me to rescue the machine I would like to know if I am able to get a warranty claim
or
What steps I need to take to to establish the problem aside from what I have already done:
Fresh install of windows
RAM checks & RAM Removal
SDD removal / clean fingers and re-install
If I need to replace the CPU/GPU could I replace with AMD ryzen 5800u with this SER 4? or will I need to do other changes to the system to get this machine back up and runnung in a stable state.
I ask this because I am not able to locate anywhere to purchase a replacement CPU AMD Ryzen 4800u
Your prompt response is appreciated.
Katherine
