DevArtist I received my Mini PC 12 with W11 Pro and want to move it into Proxmox as VM. So I need to reinstall Windows and will require a/my product key for W11 Pro. Can you provide me the key please? Product:Mini PC M SN:BN1005FH40906 MINIS12 PRO-A-16512SDOW64PRO-8/XB
Louvets I looking for the Windows Activation Key for my new computer. Please find attached pictures of the product information from the PC and from the box Thanks,
Gabriele Good day. Please send me an activation key - Windows 11 pro is not activated after a fresh install Serial: SNA50952IG30889 - U59V1-E-8256SD0W64PRO-A. Thank you, Gabriele
Beelink CS-Bettie nyo85 I have re-sent the Key for your private message. Please check it. richrKr synn pained The keys have been sent to your respective private messages. Please check them respectively. Please use it as soon as possible because the key has a time limit. Please do not share with others, otherwise it may damage your machines.
pained Hi - can I have a Windows 11 Key please? I just got a GTi14, and want to try Linux + Windows 11 VM. SN: Y155H4JG00088 Thanks!
s3bash Hi I am unable to send via private message due to some issue with recaptcha not showing up. I would like to reinstall my system from fresh. May I please get the windows 11 pro key. Thank you
Beelink CS-Bony s3bash Please send us a picture of SN on the bottom of the PC. After you send us the sn picture, we will provide you with the key.
Beelink CS-Bony Skollgrim Please send us a picture of SN on the bottom of the PC. After you send us the sn picture, we will provide you with the key.
