• #1
my games crashes all the time with a gti 12. connected to the ex dock with a graphic
Card XFX 7900 xt.. any solution? can ex dock be updated firmware? Or another solution?
Please help
Gti 12 bios T201
Graphic card radeon Xfx 7900xt
Thanks for your time
    Asier Hi there,
    The EX dock doesn’t have the firmware to update.
    What games are you playing ?
    Does the games crash if you don’t connect to the ex dock ?
    It happens with big games. Doom Eternal. Warhammer 40k 2, Hellblade 2, etc. They crash. You play for ten minutes, 30 minutes… and they freeze. You have to restart the system. The graphics card has been tested on another computer and it works fine with the same games. I have seen a solution (which I don’t know if it would work in my case) by going into the BIOS but for Asus boards but it is different from the Beelink BIOS. And I don’t know if it will be the same cause. Thanks
    My system exhibits instability too when enabling C-states in BIOS. Why don’t you give it a try.
      • Edited
      • #5
      entau How to disable C states in bios? Where exactly are they? I am very new to this.
      Thank you very much
      [unknown] I found it and did it. It still fails.
      5 days later
      How about you update the driver of the EGPU ?
      If the problem persists, you can send the item back for checking
        4 days later
        entau
        Please go to AMD Driver Download Page:
        https://www.amd.com/en/support
        Steps to Download and Install the Driver:
        Go to the link above.
        Use the Auto-Detect and Install Tool (recommended for ease of use) or manually select your product:
        Product Type: Graphics
        Product Series: Radeon RX 7000 Series
        Product Model: Radeon RX 7900 XT
        Click Submit to find the latest driver for your GPU.
        Download and install the driver by following the on-screen instructions.
        Notes:
        Ensure you uninstall any previous GPU drivers before installing the new ones to avoid conflicts.
        Restart your system after the installation is complete.
