bios ver = v29
enclosure = acasis ec-7352
OS = WIN11 24H2
Intermittent logical errors occur when using SCSI type enclosures in SER8
I don’t get this error when I use it on my another desktop
All ports show the same symptoms regardless of front rear USB A type or C type
event log
id 153 : IO operation attempted again at logical block address 0×52e300 on disk (PDO name: \Device\00000056).
id 129 : Reset to device, \Device\RaidPort1, was issued
    kingong
    Please send us a picture of SN on the bottom of the PC and a picture of the purchase record.
    Please send a complete screenshot of your current BIOS version page.
    Here is a link on how to check the BIOS version:https://url.bee-link.cn/EqEu
    After you provide the current BIOS version, we can determine which one your BIOS is suitable for?
    Have a nice day!
    Best regards!
    Wendy
    Customer Support
      kingong
      Hi THERE
      Your BIOS is the latest .
      try this :
      Press Win + X and select Command Prompt (Admin) or Windows Terminal (Admin).
      Open the Command Prompt as an administrator:
      type:chkdsk /f /r
      then enter to fix it
        a month later
        support4
        I can’t solve it with the way you told me
        if use hdd power saving option which is detail option in windows power saving option
        It happens when the hdd power saving mode is released
        And this symptom does not occur in other pc but only in ser8
          kingong
          Could you please send us a picture of faulty screen?
          Here is the potential solutions: First, Please turn off the PC , unplug the power supply, and press the CMOS button (if no CMOS button, please put the pin in the CMOS pinhole and press it ) for about 10 seconds , restart the PC after ten minutes. Here is the tutorial https://mega.nz/file/XypwTISY#DVT0BsjOgiPkZ-drQaj88JH9Z7f7qpKGP2E3nMHW8ms or https://url.bee-link.cn/5FdW
          Best regards!
          Yue
          Customer Support
