- Edited
The difference between lying on its side and lying flat. I am considering fixing an external antenna straight to the AX200 card. Do you think it will help? my ISP speed is 600/500Mbps
You can choose to place it vertically, so that the wifi speed is faster.
If you fix the external antenna to AX200, it will also help with wifi.
i’m having big Wi fi troubles too: no connection if you launch a application or game and i’m sending email to the support now.
did the external will solve the problem? which reference of Antenna should i buy?
thanks for help
hi there
5.CLR CMOS
Secondly, Please hit the “CLR CMOS” button for about 10 seconds.
Ten minutes later, plug the power supply and HDMI cable, turn on the PC again,
6.Please right click the windows–computer management–double click Services–①Wlan auto config–start the service, ②WWAN Auto config —start the service.
7.Go to the windows terminal (admin) > type in : sfc /scannow > then wait until finished.
8.Here` s a software for you to fix the WIFI issue, see if it works.
Please try this software https://mega.nz/file/X7hGVZwb#1tA5wEJhxH8BDtKxeB5qS2ZiIEUByAVZoOnzhSf4-Pg
9.Disable Fast Startup
In Control Panel, click the Power Options. Select the Choose what the power buttons do. Uncheck the “Turn on fast startup.”, click save changes.
Hi,
i experienced the same issue with weak wifi signal. i didnt noticed it as its wasnt me using the PC. i bought a external antenna but it didnt worked maybe due to my old router issue. Frustrated, in the end i resorted to this. Its ugly, but it works.
from around 20-30mbs, (roblox unable to load), to 200-250mbs (happy gaming)
angerydadd
Hi thanks for sharing . did you take out the wifi card to attach on the outside?
