support7 I have downloaded the zip with the drivers and three ccfolders appear to install RAID.
Many drivers are missing, if not all, chipset, sound, wifi bluetooth, ethernet etc…
And also there is not the latest BIOS update to know if the most recent version is installed.
In the SER9 Pro folder with the Ryzen HX 370 I have seen that there are two versions:
V1 starts with serial Y or B
V2 starts with serial D
What are the differences?
My SER9 Pro has the Ryzen 9 AI 365, I need the files for this CPU version (my serial number start with B). Thank you.
