- Edited
I have a Beelink GTi14 Ultra AI PC with an Intel® Core™ Ultra 9 185H processor. I recently purchased two Kingston 48GB DDR5-5600 SO-DIMM memory modules (model: KVR56S46BD8-48) (here’s the link to the product on Amazon):
https://www.amazon.com/Kingston-ValueRAM-5600MT-Non-ECC-KVR56S46BD8-48/dp/B0CY2WDZCN
After installing the new RAM, I noticed a red LED light inside the PC (which was not lit before). The PC failed to boot, and I was unable to access the BIOS.
I removed the new RAM and, after reading a forum post, updated the BIOS from version T102 to T108. I also reset the BIOS settings to default. The PC now boots successfully with the old RAM, and the BIOS version shows as T108.
However, when I reinstalled the new RAM, the red LED no longer lights up, but the PC still fails to boot, and I cannot access the BIOS. I tried installing only one RAM module at a time, testing both the lower and upper slots, but neither configuration worked—the PC still does not boot.
What else can I do to resolve this issue? Are there any specific BIOS settings I need to configure for this RAM to work properly?
Thank you in advance for your assistance!
