Beelink CS-Bettie
Thanks for your reply.
- No error appears - it simply freezes.
- The SSD is already set as the first boot option
- I’ve tried with two different SSDs so I’m certain they’re securely placed.
- As I mentioned I’ve attempted to reinstall several different systems with similar results
Is there a firmware update available for this PC?
[unknown]
Thank you for the suggestions. Unfortunately, both Secure Boot and Fast Boot are turned off already and the same issue occurs. I’ve tried booting from three of the four USB ports, using several different USB devices in each port, and the 22.1 version of Linux Mint is the most recent version available.
I’m hoping that Beelink has an updated firmware version for this PC, as I think that you’re right when you say it’s a compatibility problem with the hardware.
[unknown]
