- Diagnose USB Hardware Issues
a. Test USB Ports with a Linux Live OS
Purpose: Confirm if the issue is hardware-related (faulty USB ports) or Windows/driver-specific.
Steps:
Create a Ubuntu Live USB (use another PC):
Download Ubuntu: https://ubuntu.com/download/desktop
Use Rufus (https://rufus.ie/) to write the ISO to a USB drive.
Boot the SEi12 from the Live USB (press F7/F12 during startup to select boot device).
Test all USB ports with your keyboard/mouse and other devices.
If the issue persists: Hardware fault (return the unit).
If the issue vanishes: Windows/driver problem (proceed below).
b. Check USB Power Delivery
Issue: Weak power output to USB ports causing disconnects.
Fix:
Avoid high-power devices (e.g., external HDDs) on unpowered hubs.
Use a powered USB hub for peripherals.
- Fix Windows Driver Conflicts
a. Install Beelink-Specific Chipset/USB Drivers
Download drivers for your SEi12 model:https://mega.nz/file/v7xGwZBA#bPPiVA4J4m7mbjFUs5hKd5natdyP7W-PUC4vUFtJfws
Install Chipset, USB 3.↉.1, and Serial IO drivers.
b. Disable USB Selective Suspend
Prevent Windows from powering down USB ports:
Press Win + R → Type powercfg.cpl → Open Power Options.
Click Change plan settings → Change advanced power settings.
Expand USB settings → USB selective suspend → Set to Disabled.
c. Force Reinstall USB Controllers
Open Device Manager → Expand Universal Serial Bus controllers.
Right-click each USB Root Hub → Uninstall device → Check “Delete the driver software.”
Reboot to let Windows reinstall drivers.
- Eliminate Software Sluggishness
a. Disable Background Bloatware
Open Task Manager → Startup tab → Disable non-essential apps.
Uninstall preloaded software (e.g., McAfee, unused utilities).
b. Reset Windows 11
Keep your files but refresh the OS:
Go to Settings → System → Recovery → Reset PC.
Choose Keep my files → Follow prompts.
c. Test with LibreELEC
Does it void warranty? No, unless physical damage occurs during installation.
Steps:
Download LibreELEC: https://libreelec.tv/downloads/
Use Rufus to write the image to a USB drive.
Boot from the USB and test performance.
