I want to check if there is a BIOS update for my PC.
Model: 9Y.UP3450834B10 (Box Sticker) / SER6-P-E 321TBEJ0W64PRO-DP/XΑ
Serial: Y69004IF00302
BIOS Version from Main: 2.22.1292 ©AMI 2024
Also, I would like to obtain a zip file with the drivers, as I would like to wipe my machine and reinstall Windows 11. I have my product key saved to my Microsoft account already.
Finally, I have read there was an issue with WiFi that I periodically experience. Something to do with the antenna placement. From what I remember reading, it was an easy fix. Please describe how I can fix this antenna placement issue or if I can get a replacement wifi module.
Thank you!
