Mark.wm
Here are possible solutions :
1.Unplug USB Dongle
please try to disconnect all the worked USB dongles. Here USB dongle means the device which is connected to your computer with a USB cable including blue tooth, SD card readers, flash drive, wireless mouse dongle, and more.
2.Reset the PC. Start your PC, just as Windows attempts to load (spinning dots), press and hold Power Button for 5 - 10 seconds to perform a Hard Shut Down
Do this twice
Then start the Reset
3.Please reinstall the system. Here is the tutorial https://url.bee-link.cn/74zu
4..Please check if the SSD can be recognized or not. Please repeatedly press delete key as soon as you turn on the PC, go to BIOS. On Save&Exit page, please check if you can see the SSD information. If you cannot see it, the SSD might have failed.
