Beelink CS-George Hello there, Please press delete key as soon as you turn on the PC, so that you can go to BIOS. Please send us a picture of the Main page. We will check if you need to update the BIOS.
Beelink CS-George Hi there, please update the latest BIOS https://url.bee-link.cn/MuDG, here is the tutorial https://url.bee-link.cn/Hzcm
albgr Beelink CS-George Hi. I have updated the bios with the files you mentioned but the problem is still there. I am starting to think that it is a problem with the placement of the antennas and coverage because the mini pc case is metal. As I mentioned in the first comment, with another mini pc of yours but made of plastic I have not had these problems. If this cannot be solved I will have to return the computer. It is a shame because otherwise I am delighted with it. Is there any model with similar features and price that does not have this problem?
Beelink CS-George albgr Hi there, SER9 , GTI12, GTI13 ,GTI14 don’t have the problem. Would you like to send this item back for checking and analyzing ?
albgr Beelink CS-George Hi. I will look at those models. Sending the computer for you to check it seems complicated to me because of the shipping costs, customs, etc… Thank you very much for offering it, I really appreciate it.
Beelink CS-George albgr Hi there, Thanks for the reply. If you are willing to send it back, we can bare the shipping cost and the custom.
albgr Beelink CS-George Thank you very much for the offer. I have decided to keep the computer because I am very happy with it except for the Bluetooth and WiFi. The other models you mentioned are out of my budget. I bought a Bluetooth via USB and I am using that one. I lose a USB port but I prefer that to being without the computer. Thank you very much for your attention.
Logic7 albgr I am running into this same issue. Did you ever do anything to fix this? Just sucks considering it’s great other wise. The Bluetooth going in and out is brutal. I have switched to wired controllers
KDDRock Installing an aftermarket external wi-fi antenna did wonders for my connection. It flies like a hornet now. :-)
albgr Logic7 I installed a USB Bluetooth adapter on the front of the computer because the problem is that the aluminum casing causes the signal to be lost from both the Wi-Fi and the internal Bluetooth. It’s a problem with the computer’s construction.
