lostform
There is no image file for resetting the system, but there is one for reinstalling the system. Here are the specific steps:
- Reset your PC. Start your PC, just as Windows attempts to load (spinning dots), press and hold Power Button for 5 - 10 seconds to perform a Hard Shut Down
Do this twice
Then start the Reset
2.Re-install the system.
Please go to MS official for the latest system .
Windows11 tutorial: https://url.bee-link.cn/74zu
Windows10 tutorial:https://url.bee-link.cn/dbOB
Best regards!
Yue
Customer Support
