Hello!
I purchased a Beelink SEI10 Mini PC 10th Generation Intel i5-1035G1 Processor. It is running Win 11 Pro 21H2 because Windows Update states the PC does not have TPM 2.0.
Here are the PC’s specifics:
• SEi-1035G1-16500O10W65PRO-V13
• S/N: 1035G2LF000111
• BIOS Version: IB1V103
• Build Date and Time: 04/26/2022 19:47:36
• EC Version: 00.12
From TPM.MSC: “Compatible Trusted Platform Module (TPM) cannot be found on this computer. Verify that this computer has a 1.2TPM or later and it is turned on in the BIOS.”
Hopefully the information above is helpful. So, could you tell me:
1) Does this PC have TPM 2.0 support?
2) How do I get it turned on?
Thank you!!
