Hello! I bought a Beelink mini PC and will be using it remotely. The PC will be plugged into a Kasa smart plug. I need to modify the BIOS to allow me to remotely turn on the PC through power cycling the smart plug. The problem I am running into is the setting in BIOS I cannot find. Can you please help me with this or let me know if “Power on After AC Loss” is labeled something else? Will I need to update the BIOS?
BIOS Version/Date: American Megatrends International, LLC. SER5H512, 9/6/2024
SMBIOS Version: 3.3
Processor: AMD Ryzen 7 PRO 5850U with Radeon Graphics, 1901 Mhz, 8 Core(s), 16 Logical Processor(s)
SN: B58505DH90788
Best regards,
Andrew
This is where is should be but is not. I also checked every folder and sub-folder and did not see anything that could be what I need.
