I’m wondering if I could get a spec sheet for a SER5 PRO with AMD Ryzen 7 5850U, 32GB RAM, 1TB NVMe SSD. This was purchased about a month ago on Amazon. I don’t see it listed anywhere on the BeeLink website. Thanks.
    dandroid
    Hi,there
    Please send us a picture of SN on the bottom to confirm.
    Thanks for your patience and your understanding.
    Image description
    Please note that the 120KB upload restriction made this a bit difficult! Thanks!
      dandroid
      The SSD of SER5 5850 is M.2 SSD NVME 2280, which supports a maximum of 2TB SSD.
      Is there any other program running on the machine when you transfer the data
      You can try to clear CMOS firstly: First,please unplug the power supply and HDMI cable.
      Please press the pinhole of “CLR CMOS” with a pin for about 10 seconds.Ten minutes later, plug the power supply and HDMI cable, turn on the PC again. Please wait about one or two minute, if you can go to the system.
      Please repeatedly press delete key as soon as your restart the PC, go to BIOS. Go to Boot option, enable fast boot, press F4 to save.
      Here is the tutorial https://mega.nz/file/2nIRGaYI#M2aIM2bkOJshrhE8sK8MNiKopfyHlqyjnn86TypZp2w
      Have a nice day!
      support10, I think you added your answer to the wrong thread here, I wasn’t asking about all that.
      I am looking for a specifications sheet for my computer!
      Hello, support10, Thank you, but I believe you were answering the wrong thread, I did not ask about CMOS.
      I am looking for a spec sheet for my mini PC!
        dandroid
        It has been sent to you through PD, please check.
        Best regards!
        Yue
        Customer Support
        9 days later
        Another question related to the same mini PC (SER5 PRO with AMD Ryzen 7 5850U):
        Please tell me if I am correct that this PC can accommodate both of 2 TB M.2 NVMe SSD, and a 2 TB SATA-3 SSD, so total of 4 TB split between the two types of storage?
          dandroid
          You’re right.
          The SER5 5850 supports M.2 SSD NVME 2280 and SATA 2.5in HDD (7mm) , both MAX 2TB.
          Best regards!
          Yue
          Customer Support
            a month later
            support6 The SER5 5850 supports M.2 SSD NVME 2280 and SATA 2.5in HDD (7mm) , both MAX 2TB.
            Thats the beauty of using Forum search. Sometimes you find the answer to questions, you didnt even think of yet.
              AmBush
              That`s right !
              Please let me know, if you have any query , i am glad to help.
              Your satisfaction is our top priority !
