William Hello beelink I’ve purchase a ser8 and install linux with full erase. Now i need install windows 11 back, could you please provide me the windows 11 pro activate code? Here’s my sn info 99.CN3680934G10 SN:C88454JG10577 SER8-E-321TBVK0W64PRO-DP/XA
[deleted] Hello, I have installed a larger hard drive in my new S12 Pro, and Windows fails to activate. Please, provide a key for activation. Thank you!
Beelink CS-Yvette bluegrassbandit42 Hi there, Please check your private message Brillo Please check your private message Brillo Please check your private message
Quinn Hi, I just reset my 6Max and windows fails to activate. Please provide a key for activation. Thanks
Игорь thank you very much. and another question is where can I find all the drivers and Windows itself if I need to reinstall the system.
Brillo I just did a Windows update on my new PC and it says that I need to Activate Windows and it won’t activate. Please provide a new key. Thanks!
phether We are trying to activate a new unit with Windows 11 Pro that it came with and Microsoft is stating it can not activate. I am including a picture of the Serial number on the back in hopes you can provide a valid Key Code for Windows 11 Pro.
