Hi @Beelink, could you clarify if the 64GB/2TB version comes with one 2TB SSD or two 1TB SSDs? I got a reply from support saying it’s two 1TB SSDs, which is a pity, as I’d really like to upgrade the storage but if there are already two SSDs installed I cannot add a bigger one without throwing one pre-installed away.
But in the review above I see the author opens the case and there’s one 2TB SSD.
Please clarify. This is really the only matter I’m hesitating about before purchasing the 64/2 version (32/1 does not work for me as I need a lot of RAM)
