I bought a SER5 MAX AMD Ryzen7 5850U 16GB DDR4, it worked fine, but I wanted to increase the memory and bought 2×16GB modules from this link. I installed them and the computer stopped booting, I can’t even enter the BIOS, please help.
Link to new memory:
https://aliexpress.ru/item/1005004816183114.html?spm=a2g2x.orderdetail.0.0.5e044aa6wT3rph&sku_id=12000030598034341&_ga=2.146496497.471112923.1741189830-1789178592.1737737096
2×16Gb 3200MHz
Image description
Image description
    Lefard
    The Ser5 5850 supports SO-DIMM DDR4 16GB/32GB.
    Will the problem still occur if you use the original DDR again?
    First, Please turn off the PC , unplug the power supply, and press the CMOS button (if no CMOS button, please put the pin in the CMOS pinhole and press it ) for about 10 seconds , restart the PC after ten minutes. Here is the tutorial https://mega.nz/file/XypwTISY#DVT0BsjOgiPkZ-drQaj88JH9Z7f7qpKGP2E3nMHW8ms or [https://url.bee-link.cn/5FdW] If the problem persists, please try other solutions:
    ②Please take out the RAM ,please clean the contacts of the RAM with a rubber. Here is the tutorial [https://url.bee-link.cn/AzzB] or https://mega.nz/file/7nwDmCaL#UyzSmVkqJG8HW9dhjHhLkkzdP9gt2Br3xyCG1SCdbrA
    Best regards!
    Yue
    Customer Support
      support6 Will the problem still occur if you use the original DDR again?
      No, with original memory PC works fine.
      I did all the operations you listed, but the computer didn’t start with new memory. New memory works fine in another PC, i tested it with MemTest86 v11.2
      This laptop has 4GB of non-removable memory, so the total memory with one new module is about 20GB.
      support6 ④Please check if the fan spins?
      After a few seconds the fan turns off.
      support6 ⑤Please tell us if the Keyboard light is on ?(Very important). If the keyboard light is on, it should go to the system, we need to troubleshoot HDMI or the monitor.
      The keyboard light is off.
      Image description
      Image description
        Lefard
        Hi there
        if you try only use one new RAM inside , will that work ?
          support4 if you try only use one new RAM inside , will that work ?
          I tried, none of the new memory modules work in any of the ddr slots, I can’t even enter the BIOS.
            Lefard
            Hi Lefard
            The RAM in the link seems no problem .
            would you like to take pics on both sides of the RAM for us to further confirm?
            have you tried other Brands to test ?
            Memory from other brands works fine, but it is smaller and slower.Image description
            Image description
            Upgrade your SER5 MAX AMD 5850U with high-speed RAM for enhanced performance. Optimize multitasking and efficiency effortlessly. Perfect for professionals using Dreisatz Excel, ensuring smooth calculations and seamless workflow. Maximize your system’s potential!
              dreisatzrechnerr
              My friend, do you also need to update the BIOS?
              If so, pls send us a picture of SN on the bottom of the PC.
              Please press delete key as soon as you turn on the PC, so that you can go to BIOS. Please send us a picture of the Main page.
              We will check if you need to update the BIOS.
              Best regards!
              Yue
              Customer Support
