Hello
I actually already did clear the CMOS with the pin, and I did the change in the BIOS to 65w as per the instructions, but unfortunately you can see in my screenshot that it’s not working for 65w in Windows. Cpu-Z reports max is 54w. And running CPU stress, the main cores are maxing around 4400 not 5100.
Is this a bug with the BIOS version .73?
Can you confirm the BIOS version to use? I noticed on your instructions for changing to 65w , it says for models serial starting “Y” or “C” but my model SN starts “B”.
Anything else to try?
