Hi, my brother wanted to give his Ser8 to our dad and decided to do a factory reset. Unfortunately Factory Reset made the SER8 unusable. Everytime we try to continue through the windows setup, it will fail due to Device Power Failure error and we do not know why. Would like to get some help please!
    drey
    Could you please provide the error reporting screen after the reset?
    Below is our reset tutorial for you to try:
    1)Enter the safe mode, and reset the system.
    Do this many times until Windows boots into the Recovery Environmen.
    2)If Windows will boot into the Recovery Environment and from there you can access System Repair, Safe Mode, Command Prompt . . . etc.
    3)If the above fails, go to Troubleshoot - Advanced Options - Reset this PC
    Then start the Reset
    Please feel free to contact us with any questions!
    Thank you for your patience and understanding!
    Best regards
    Bettie
    Customer Support
