Samvan I just received my GTi13 and docking station. How do I tell if the docking station is the Pro version? cuz the model number says EX without the Pro designation. In other words, how do I tell if the docking station is the one that has the PCIe 5 chips?
scdang Samvan I think it’s a passthrough.. So if your GTi13 has pcie 5, then it’ll use that interface. The new GTi Ultra on the site shows it ahs a pcie 5 ×8 slot, but my GTi14 Ultra 9 has only pcie 4.0 ×8 slot.. not that it matters much
Beelink CS-George Samvan Hi there, could you please send us a picture of the SN on the back of the dock ?
Samvan This is my SN. Please check for me. Also, are there any known issues connecting a RTX 5080 to the new dock’s PCIe 5.0 interface? I have a GTi13 PC (i9-13900 HK).
Beelink CS-George Samvan Hi there, GTi13 doesn’t support GEN5 at the moment, so please set it to GEN 4 in the BIOS.
Beelink CS-George Samvan Hi there, here is the tutorial https://buildin.ai/lizong/021dcc27-0e1a-4f94-8e42-6fd2f6e5c1eb
Samvan you said “GTi13 doesn’t support GEN5 at the moment” what does it require to enable GEN5 support? a BIOS update? or there’s no possibility to enable GEN5 with GTi13?
