Hi, I had the same problem yesterday (12.04.25).
I just want to share my experience so nobody else makes the same mistakes.
Well, it all started with the driver update (25.3.1). Just after that, monitor got black and then the eternal loop started with the BSOD. I tried to restore the system and realized that had no restoration points saved. Tried restoring from web and local machine and got always the same error that the operation could not be completed due to some error.
My mistake then was trying with all the youtube tutorials I found to try to restore my pc from CMD. Don’t know how exactly but I ended up disabling my pin (windows).
After checking the beelink forums I found that what the problem was, so I needed to try the bios update. The problem is that I only had a 64GB usb drive with me and couldn’t format it with FAT32 (and also didn’t want to f*ck it again) so… back to check another youtube tutorial.
After formatting the usb drive and booting from it got another error. I just needed to disable safe boot from system menu and then everything went ok.
Well, after the bios update I just needed to reinstall the Adrenaline software (don’t know why it uninstalled) and now everything seems fine.
So just disable safe boot from system menu and upgrade the bios. Problem solved. Don’t try to fix it by urself using youtube tutorials xD
