rktchip https://www.tomshardware.com/pc-components/cpus/amds-microcode-vulnerability-also-affects-zen-5-cpus-granite-ridge-turin-ryzen-ai-300-and-fire-range-at-risk Is there a BIOS update to fix this vulnerable in the works? Or was it already patched? Looks like AI 370 is on the list of affected units. SER9.
Beelink CS-George Hello there, Please send us a picture of the SN on the bottom of the PC. Please press delete key as soon as you turn on the PC, so that you can go to BIOS. Please send us a picture of the Main page. We will check if you need to update the BIOS.
rktchip Beelink CS-George I’m running the .73 bios for the SER9 but that’s not the question. https://www.amd.com/en/resources/product-security/bulletin/amd-sb-7033.html Please see the CVE-2024-36347 which affects the AMD CPU. AMD says they released patch to fix the vulnerability March 20, 2025 so we are not protected until we receive a newer BIOS that has the following Platform Initialization (PI) firmware update as noted: StrixHaloPI-FP11 1.0.0.1 (2025-03-20)
Beelink CS-George rktchip Hi there, please send us a picture of SN on the bottom of the PC and a picture of the Main page of the BIOS. We will transfer it to our R&D for checking.
