justme123 Hi, Would like to confirm if the stock thermal paste in SER7 Pro is liquid metal? Also, is there any instruction video on how to disassemble & re-pasting available?
support1 justme123 Hi there, it is a mixed liquid metal. We only suggest the professional to do the thermal paste change. It would ruin the CPU with malpractice. Here is the tutorial https://dr.bee-link.cn/download/dXBsb2Fkcy9UdXRvcmlhbC9Ib3ctdG8tYXBwbHktdGhlLUNQVS1wYXN0ZS10by10aGVybWFsLXN5c3RlbS0lRTUlQTYlODIlRTQlQkQlOTUlRTclQkIlOTlDUFUlRTYlOTUlQTMlRTclODMlQUQlRTklOTMlOUMlRTclQUUlQTElRTYlQjYlODIlRTclQTElODUlRTglODQlODJfMjAyNC0wNS0xNF80LTIyLTE4LnppcA==/h/dac0415deab688904c6c8fc4f21843b1
justme123 @support1 TQ for your reply. Can you provide answers to my questions below: Red circles in the picture: Removing these 5 screws with get access to the thermal paste? A (silver plate) : What components are underneath. Is there thermal pads on the underside? B (black sticker) : What is directly under the black sticker? thermal paste? Is the black coin CMOS battery? If yes, can provide info on battery type. Thank you.
support1 justme123 1–yes 2-Not sure, I did not open it before. 3–Not sure, I did not open it before. 4.–Yes. The type is CR2032
