Teguh Hi admin, My mini pc GK Mini can not booting, there are error “no media presence” . What should I do? Perhaps you could help me Regards, Teguh
Beelink CS-Yvette Teguh Hi there, Hello there, Please send us a picture of the purchase record and a picture of the SN on the bottom of the PC. When the error shows up , please press ESC or enter key to see if you can skip this error. Please press delete key as soon as you restart the PC, so that you can go to BIOS. Then go to boot page, set SSD as the first option. Please take out the SSD and reseat it securely. Please reinstall the sytem. Here is the image https://mega.nz/file/j6JhwCrS#KNOpbcT-tdL_iqPIC-Ym9R2vqcVS6yTvIMQcKx9bbxY Here is the picture tutorial https://mega.nz/file/KjZHyIqB#0EEVnG_1fWYCq_qL7GUYFGuD7nKqlV8FZWu78SVGXS4 Here is the Video tutorial https://mega.nz/file/rjw3DLjB#oCO056vM5R3bB2f1n9Kqj9aTF7eHDqGsmVghNekhsP4
Devilthrone Hi Teguh, the “no media presence” error usually means that your mini PC does not detect the boot drive, so check BIOS to see whether the SSD is recognized. If not, then reseat the drive or test on another system. Hope this is helpful.
Teguh Beelink CS-Yvette Thank you I purchased GK mini from Indonesia, here is the serial number : Devilthrone Thank you. How to do reset the SSD drive?
Beelink CS-Yvette Teguh Please take out the SSD and then put it back, make sure it is connected firmly. Please repeatedly press delete key as soon as you turn on the PC, go to BIOS. On Save&Exit page, please send us a picture of it.
