Thanks for the reply!
I have tried sudo acpi_listen, but do not see any output from it when the power button is pressed. I pressed the power button over 10 times. To test that acpi was working correctly I also plugged headphones in and out. Here is the output of the program:
$ sudo acpi_listen
jack/microphone MICROPHONE plug
jack/headphone HEADPHONE plug
jack/microphone MICROPHONE unplug
jack/headphone HEADPHONE unplug
Here is the output of dmesg
$ sudo dmesg | grep -i acpi
[ 0.000000] BIOS-e820: [mem 0x000000000a200000-0x000000000a237fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000006d5d7000-0x000000006d6d6fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000006d6d7000-0x000000006f6d6fff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x000000000a200000-0x000000000a237fff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x000000006d5d7000-0x000000006d6d6fff] ACPI data
[ 0.000000] reserve setup_data: [mem 0x000000006d6d7000-0x000000006f6d6fff] ACPI NVS
[ 0.000000] efi: ACPI=0x6f6bc000 ACPI 2.0=0x6f6bc014 TPMFinalLog=0x6f688000 SMBIOS=0x78053000 SMBIOS 3.0=0x78052000 MEMATTR=0x62d0d118 MOKvar=0x780cf000 INITRD=0x615e3098 RNG=0x6d677018 TPMEventLog=0x6d66c018
[ 0.004001] ACPI: Early table checksum verification disabled
[ 0.004004] ACPI: RSDP 0x000000006F6BC014 000024 (v02 ALASKA)
[ 0.004009] ACPI: XSDT 0x000000006F6BB728 000164 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.004015] ACPI: FACP 0x000000006D6CC000 000114 (v06 ALASKA A M I 01072009 AMI 00010013)
[ 0.004019] ACPI: DSDT 0x000000006D6C3000 008228 (v02 ALASKA A M I 01072009 INTL 20230331)
[ 0.004021] ACPI: FACS 0x000000006EE6D000 000040
[ 0.004023] ACPI: SSDT 0x000000006D6CE000 0083FE (v02 AMD AmdTable 00000002 MSFT 04000000)
[ 0.004024] ACPI: SSDT 0x000000006D6CD000 000309 (v02 ALASKA CPUSSDT 01072009 AMI 01072009)
[ 0.004026] ACPI: FIDT 0x000000006D6C2000 00009C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.004027] ACPI: MCFG 0x000000006D6C1000 00003C (v01 ALASKA A M I 01072009 MSFT 00010013)
[ 0.004029] ACPI: HPET 0x000000006D6C0000 000038 (v01 ALASKA A M I 01072009 AMI 00000005)
[ 0.004030] ACPI: UEFI 0x000000006EE6B000 000048 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.004031] ACPI: FPDT 0x000000006D6BF000 000044 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.004033] ACPI: VFCT 0x000000006D6BA000 004484 (v01 ALASKA A M I 00000001 AMD 33504F47)
[ 0.004034] ACPI: SSDT 0x000000006D6B1000 007EA6 (v02 AMD AMD CPU 00000001 AMD 00000001)
[ 0.004036] ACPI: BGRT 0x000000006D6B9000 000038 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.004037] ACPI: TPM2 0x000000006D6B0000 000050 (v05 ALASKA A M I 00000001 AMI 00000000)
[ 0.004039] ACPI: SSDT 0x000000006D6AE000 00169E (v02 AMD CPMDFIG2 00000001 INTL 20230331)
[ 0.004040] ACPI: SSDT 0x000000006D6AB000 002AA6 (v02 AMD CDFAAIG2 00000001 INTL 20230331)
[ 0.004041] ACPI: SSDT 0x000000006D6AA000 000E8B (v02 AMD OEMACP 00000001 INTL 20230331)
[ 0.004043] ACPI: SSDT 0x000000006D6A0000 009A53 (v02 AMD CPMCMN 00000001 INTL 20230331)
[ 0.004044] ACPI: WSMT 0x000000006D69F000 000028 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.004046] ACPI: APIC 0x000000006D69E000 000128 (v06 ALASKA A M I 01072009 AMI 00010013)
[ 0.004047] ACPI: SSDT 0x000000006D69D000 00010D (v02 MSFT MHSP 00000004 INTL 20230331)
[ 0.004049] ACPI: SSDT 0x000000006D69B000 001B84 (v02 AMD AOD 00000001 INTL 20230331)
[ 0.004050] ACPI: SSDT 0x000000006D69A000 000051 (v02 AMD DRTM 00000001 INTL 20230331)
[ 0.004051] ACPI: IVRS 0x000000006D699000 0001F0 (v02 AMD AmdTable 00000001 AMD 00000001)
[ 0.004053] ACPI: SSDT 0x000000006D698000 00096A (v02 AMD CPMMSOSC 00000001 INTL 20230331)
[ 0.004054] ACPI: SSDT 0x000000006D697000 000F5C (v02 AMD CPMACPV8 00000001 INTL 20230331)
[ 0.004056] ACPI: SSDT 0x000000006D696000 000500 (v02 AMD MEMTOOL0 00000002 INTL 20230331)
[ 0.004057] ACPI: SSDT 0x000000006D695000 0008ED (v02 AMD THERMAL0 00000001 INTL 20230331)
[ 0.004059] ACPI: SSDT 0x000000006D693000 00101C (v02 AMD GPP_PME_ 00000001 INTL 20230331)
[ 0.004060] ACPI: SSDT 0x000000006D689000 00972B (v02 AMD INTGPPC_ 00000001 INTL 20230331)
[ 0.004061] ACPI: SSDT 0x000000006D684000 004608 (v02 AMD INTGPPA_ 00000001 INTL 20230331)
[ 0.004063] ACPI: SSDT 0x000000006D683000 000D44 (v02 AMD CPMGPIO0 00000001 INTL 20230331)
[ 0.004064] ACPI: SSDT 0x000000006D682000 00008D (v02 AMD CPMMSLPI 00000001 INTL 20230331)
[ 0.004066] ACPI: SSDT 0x000000006D681000 000509 (v02 AMD CPMSFAML 00000001 INTL 20230331)
[ 0.004067] ACPI: SSDT 0x000000006D680000 000CF9 (v02 AMD WwanSsdt 00000001 INTL 20230331)
[ 0.004068] ACPI: SSDT 0x000000006D67F000 000A7F (v02 AMD SDCR 00000001 INTL 20230331)
[ 0.004070] ACPI: SSDT 0x000000006D67E000 000A39 (v02 AMD LOM 00000001 INTL 20230331)
[ 0.004071] ACPI: SSDT 0x000000006D67D000 000BC5 (v02 AMD WLAN 00000001 INTL 20230331)
[ 0.004073] ACPI: SSDT 0x000000006D67C000 000C93 (v02 AMD NVME 00000001 INTL 20230331)
[ 0.004074] ACPI: SSDT 0x000000006D67B000 000AB6 (v02 AMD GpMsSsdt 00000001 INTL 20230331)
[ 0.004075] ACPI: SSDT 0x000000006D67A000 000057 (v02 AMD GPP9 00000001 INTL 20230331)
[ 0.004077] ACPI: SSDT 0x000000006D678000 0018CE (v02 AMD UPEP 00000001 INTL 20230331)
[ 0.004078] ACPI: Reserving FACP table memory at [mem 0x6d6cc000-0x6d6cc113]
[ 0.004079] ACPI: Reserving DSDT table memory at [mem 0x6d6c3000-0x6d6cb227]
[ 0.004079] ACPI: Reserving FACS table memory at [mem 0x6ee6d000-0x6ee6d03f]
[ 0.004079] ACPI: Reserving SSDT table memory at [mem 0x6d6ce000-0x6d6d63fd]
[ 0.004080] ACPI: Reserving SSDT table memory at [mem 0x6d6cd000-0x6d6cd308]
[ 0.004080] ACPI: Reserving FIDT table memory at [mem 0x6d6c2000-0x6d6c209b]
[ 0.004080] ACPI: Reserving MCFG table memory at [mem 0x6d6c1000-0x6d6c103b]
[ 0.004081] ACPI: Reserving HPET table memory at [mem 0x6d6c0000-0x6d6c0037]
[ 0.004081] ACPI: Reserving UEFI table memory at [mem 0x6ee6b000-0x6ee6b047]
[ 0.004081] ACPI: Reserving FPDT table memory at [mem 0x6d6bf000-0x6d6bf043]
[ 0.004081] ACPI: Reserving VFCT table memory at [mem 0x6d6ba000-0x6d6be483]
[ 0.004082] ACPI: Reserving SSDT table memory at [mem 0x6d6b1000-0x6d6b8ea5]
[ 0.004082] ACPI: Reserving BGRT table memory at [mem 0x6d6b9000-0x6d6b9037]
[ 0.004082] ACPI: Reserving TPM2 table memory at [mem 0x6d6b0000-0x6d6b004f]
[ 0.004083] ACPI: Reserving SSDT table memory at [mem 0x6d6ae000-0x6d6af69d]
[ 0.004083] ACPI: Reserving SSDT table memory at [mem 0x6d6ab000-0x6d6adaa5]
[ 0.004083] ACPI: Reserving SSDT table memory at [mem 0x6d6aa000-0x6d6aae8a]
[ 0.004084] ACPI: Reserving SSDT table memory at [mem 0x6d6a0000-0x6d6a9a52]
[ 0.004084] ACPI: Reserving WSMT table memory at [mem 0x6d69f000-0x6d69f027]
[ 0.004084] ACPI: Reserving APIC table memory at [mem 0x6d69e000-0x6d69e127]
[ 0.004084] ACPI: Reserving SSDT table memory at [mem 0x6d69d000-0x6d69d10c]
[ 0.004085] ACPI: Reserving SSDT table memory at [mem 0x6d69b000-0x6d69cb83]
[ 0.004085] ACPI: Reserving SSDT table memory at [mem 0x6d69a000-0x6d69a050]
[ 0.004085] ACPI: Reserving IVRS table memory at [mem 0x6d699000-0x6d6991ef]
[ 0.004086] ACPI: Reserving SSDT table memory at [mem 0x6d698000-0x6d698969]
[ 0.004086] ACPI: Reserving SSDT table memory at [mem 0x6d697000-0x6d697f5b]
[ 0.004086] ACPI: Reserving SSDT table memory at [mem 0x6d696000-0x6d6964ff]
[ 0.004086] ACPI: Reserving SSDT table memory at [mem 0x6d695000-0x6d6958ec]
[ 0.004087] ACPI: Reserving SSDT table memory at [mem 0x6d693000-0x6d69401b]
[ 0.004087] ACPI: Reserving SSDT table memory at [mem 0x6d689000-0x6d69272a]
[ 0.004087] ACPI: Reserving SSDT table memory at [mem 0x6d684000-0x6d688607]
[ 0.004088] ACPI: Reserving SSDT table memory at [mem 0x6d683000-0x6d683d43]
[ 0.004088] ACPI: Reserving SSDT table memory at [mem 0x6d682000-0x6d68208c]
[ 0.004088] ACPI: Reserving SSDT table memory at [mem 0x6d681000-0x6d681508]
[ 0.004089] ACPI: Reserving SSDT table memory at [mem 0x6d680000-0x6d680cf8]
[ 0.004089] ACPI: Reserving SSDT table memory at [mem 0x6d67f000-0x6d67fa7e]
[ 0.004089] ACPI: Reserving SSDT table memory at [mem 0x6d67e000-0x6d67ea38]
[ 0.004089] ACPI: Reserving SSDT table memory at [mem 0x6d67d000-0x6d67dbc4]
[ 0.004090] ACPI: Reserving SSDT table memory at [mem 0x6d67c000-0x6d67cc92]
[ 0.004090] ACPI: Reserving SSDT table memory at [mem 0x6d67b000-0x6d67bab5]
[ 0.004090] ACPI: Reserving SSDT table memory at [mem 0x6d67a000-0x6d67a056]
[ 0.004091] ACPI: Reserving SSDT table memory at [mem 0x6d678000-0x6d6798cd]
[ 0.018917] ACPI: PM-Timer IO Port: 0x808
[ 0.018927] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.018946] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.018948] ACPI: INT_SRC_OVR (bus 0 bus_irq 1 global_irq 1 low edge)
[ 0.018948] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.018951] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.018952] ACPI: HPET id: 0x10228201 base: 0xfed00000
[ 0.063306] ACPI: Core revision 20230628
[ 0.204802] ACPI: PM: Registering ACPI NVS region [mem 0x0a200000-0x0a237fff] (229376 bytes)
[ 0.204802] ACPI: PM: Registering ACPI NVS region [mem 0x6d6d7000-0x6f6d6fff] (33554432 bytes)
[ 0.206058] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.206652] ACPI: Added _OSI(Module Device)
[ 0.206652] ACPI: Added _OSI(Processor Device)
[ 0.206652] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.206652] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.213652] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SBRG.EC0], AE_NOT_FOUND (20230628/dswload2-162)
[ 0.213659] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20230628/psobject-220)
[ 0.213662] ACPI: Skipping parse of AML opcode: Scope (0x0010)
[ 0.214553] ACPI: 29 ACPI AML tables successfully acquired and loaded
[ 0.219933] ACPI: USB4 _OSC: OS supports USB3+ DisplayPort+ PCIe+ XDomain+
[ 0.219933] ACPI: USB4 _OSC: OS controls USB3+ DisplayPort+ PCIe+ XDomain+
[ 0.219933] ACPI: _OSC evaluation for CPUs failed, trying _PDC
[ 0.220614] ACPI: Interpreter enabled
[ 0.220623] ACPI: PM: (supports S0 S5)
[ 0.220625] ACPI: Using IOAPIC for interrupt routing
[ 0.221068] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.221248] ACPI: Enabled 3 GPEs in block 00 to 1F
[ 0.222496] ACPI: \_SB_.PCI0.GPP0.PWRS: New power resource
[ 0.222999] ACPI: \_SB_.PCI0.GPP0.SWUS.PWRS: New power resource
[ 0.223529] ACPI: \_SB_.PCI0.GPP1.PWRS: New power resource
[ 0.224038] ACPI: \_SB_.PCI0.GPP1.SWUS.PWRS: New power resource
[ 0.224184] ACPI: \_SB_.PCI0.GPP3.P0NV: New power resource
[ 0.224507] ACPI: \_SB_.PCI0.GPP4.PWSR: New power resource
[ 0.224958] ACPI: \_SB_.PCI0.GPP5.PWSR: New power resource
[ 0.225280] ACPI: \_SB_.PCI0.GPP6.PWSR: New power resource
[ 0.225611] ACPI: \_SB_.PCI0.GPP7.P0WW: New power resource
[ 0.225894] ACPI: \_SB_.PCI0.GPPA.PWRS: New power resource
[ 0.225997] ACPI: \_SB_.PCI0.GPPA.VGA_.PWRS: New power resource
[ 0.226147] ACPI: \_SB_.PCI0.GPPA.ACP_.PWRS: New power resource
[ 0.226369] ACPI: \_SB_.PCI0.GPPA.AZAL.PWRS: New power resource
[ 0.226526] ACPI: \_SB_.PCI0.GPPA.HDAU.PWRS: New power resource
[ 0.226697] ACPI: \_SB_.PCI0.GPPA.XHC1.PWRS: New power resource
[ 0.227245] ACPI: \_SB_.PCI0.GPPC.XHC0.PWRS: New power resource
[ 0.228269] ACPI: \_SB_.PCI0.GPPC.XHC3.PWRS: New power resource
[ 0.228808] ACPI: \_SB_.PCI0.GPPC.XHC4.PWRS: New power resource
[ 0.229344] ACPI: \_SB_.PCI0.GPPC.NHI0.PWRS: New power resource
[ 0.229672] ACPI: \_SB_.PCI0.GPPC.NHI1.PWRS: New power resource
[ 0.232420] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.232425] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.232482] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.242954] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.242979] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[ 0.243000] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.243026] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.243050] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.243069] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.243088] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.243107] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.244658] ACPI: bus type USB registered
[ 0.244666] PCI: Using ACPI for IRQ routing
[ 0.254965] pnp: PnP ACPI init
[ 0.257047] pnp: PnP ACPI: found 4 devices
[ 0.262931] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.289003] ACPI: \_SB_.PLTF.C000: Found 3 idle states
[ 0.289112] ACPI: \_SB_.PLTF.C002: Found 3 idle states
[ 0.289170] ACPI: \_SB_.PLTF.C004: Found 3 idle states
[ 0.289245] ACPI: \_SB_.PLTF.C006: Found 3 idle states
[ 0.289343] ACPI: \_SB_.PLTF.C008: Found 3 idle states
[ 0.289450] ACPI: \_SB_.PLTF.C00A: Found 3 idle states
[ 0.289555] ACPI: \_SB_.PLTF.C00C: Found 3 idle states
[ 0.289652] ACPI: \_SB_.PLTF.C00E: Found 3 idle states
[ 0.289752] ACPI: \_SB_.PLTF.C010: Found 3 idle states
[ 0.289860] ACPI: \_SB_.PLTF.C012: Found 3 idle states
[ 0.289970] ACPI: \_SB_.PLTF.C014: Found 3 idle states
[ 0.290078] ACPI: \_SB_.PLTF.C016: Found 3 idle states
[ 0.290135] ACPI: \_SB_.PLTF.C001: Found 3 idle states
[ 0.290217] ACPI: \_SB_.PLTF.C003: Found 3 idle states
[ 0.290265] ACPI: \_SB_.PLTF.C005: Found 3 idle states
[ 0.290312] ACPI: \_SB_.PLTF.C007: Found 3 idle states
[ 0.290400] ACPI: \_SB_.PLTF.C009: Found 3 idle states
[ 0.290488] ACPI: \_SB_.PLTF.C00B: Found 3 idle states
[ 0.290575] ACPI: \_SB_.PLTF.C00D: Found 3 idle states
[ 0.290665] ACPI: \_SB_.PLTF.C00F: Found 3 idle states
[ 0.290741] ACPI: \_SB_.PLTF.C011: Found 3 idle states
[ 0.290832] ACPI: \_SB_.PLTF.C013: Found 3 idle states
[ 0.290916] ACPI: \_SB_.PLTF.C015: Found 3 idle states
[ 0.291003] ACPI: \_SB_.PLTF.C017: Found 3 idle states
[ 0.291164] ACPI: thermal: Thermal Zone [TZ01] (20 C)
[ 1.801733] ACPI: bus type drm_connector registered
[ 2.020192] ACPI: video: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 2.030325] ACPI: bus type thunderbolt registered
journalctl --boot | grep -i "power button|acpi" does not return any output.
Please see attached the screenshot of the bios screen.
It looks like I already have the latest kernel installed:
$ sudo apt show linux-generic-hwe-24.04
Package: linux-generic-hwe-24.04
Version: 6.11.0-24.24~24.04.1
Priority: optional
Section: kernel
Source: linux-meta-hwe-6.11
Origin: Ubuntu
Maintainer: Ubuntu Kernel Team <kernel-team@lists.ubuntu.com>
Bugs: https://bugs.launchpad.net/ubuntu/+filebug
Installed-Size: 9,216 B
Provides: kernel-testing--linux-hwe-6.11--full--generic, kernel-testing--linux-hwe-6.11--full--preferred
Depends: linux-image-generic-hwe-24.04 (= 6.11.0-24.24~24.04.1), linux-headers-generic-hwe-24.04 (= 6.11.0-24.24~24.04.1)
Recommends: linux-tools-6.11.0-24-generic, ubuntu-kernel-accessories
Download-Size: 1,766 B
APT-Sources: http://ca.archive.ubuntu.com/ubuntu noble-updates/main amd64 Packages
Description: Complete Generic Linux kernel and headers
This package will always depend on the latest complete generic Linux kernel
and headers.
N: There is 1 additional record. Please use the '-a' switch to see it
I ran sudo apt install linux-generic-hwe-24.04 anyways, rebooted the system, and retested the power button using sudo acpi_listen, but it still does not work.
Any other ideas?
