What is the acceptable voltage input for the mini PC itself? I want to power it from a battery that has an output voltage between 13-14 volts.
    Ch Hi there, May I have a picture of SN on the bottom of the PC ?
    • Ch replied to this.
      support1 I do not own one. I am researching my options. I want to know if I can power your mini-pc from a battery with a voltage between 13-14 volts. For example a Beelink Mini S12 Pro Mini.
        Ch Hi there, MINI S12 doesn’t support PD power supply. You can choose SER8,SER9, GTI12, SEI12, SEI14, GTi13, GTi14 ,which support 19V.
        You are missing my question.
        I am using a LifePo battery with a nominal voltage of 13-14 V.
        Will the barrel connection for power on the mini S12 accept a voltage between 13-14 volts?
          Ch Hi there, it is not recommended to use a power source with a voltage of 13 - 14V directly, as this exceeds the specified voltage range of the device.Using a voltage that is too high may cause damage to the Mini S12’s power supply circuit and other components, and may also pose risks such as overheating and reduced service life. It is best to use the original power adapter or a power adapter that is specifically designed for the Mini S12 and meets the required voltage and current specifications to ensure the stable operation and safety of the device.
