I just bought a Beelink mini PC 13 series today & am trying to get it all set up. I am having trouble with updates not finishing, and the PC getting hung up on the “don’t turn off your computer” screen & the PC is not allowing me to give my account full permissions as an administrator. Every time I try and install an app I’m getting various error codes.
I’ve been trying to get this updated & configured for hours now. I’m about ready to pack it up and send it back.
    forcryinoutloud
    Hi there, sorry for the trouble.
    Could you please send us a picture of the SN on the bottom of the PC ?
    1. Fix Windows Update Stuck on “Don’t Turn Off” Screen
      Wait Longer: Major updates can sometimes take hours (especially on mini PCs with slower storage). Leave it overnight if possible.
    Force Restart: If truly stuck, hold the power button for 10 seconds to force shutdown. Boot again:
    Windows will often resume updates automatically.
    If it loops, try Safe Mode:
    Interrupt boot 3 times (press power button during startup) to trigger Recovery Mode.
    Go to Troubleshoot > Advanced Options > Startup Settings > Restart.
    Press F4 or 5 (to enable Safe Mode with Networking).
    In Safe Mode, run Windows Update Troubleshooter (Settings > Update & Security > Troubleshoot).
    Manually Reset Windows Update (if updates keep failing):
    Open Command Prompt as Admin (right-click Start menu > Windows Terminal (Admin)).
    Run these commands in order:
    net stop wuauserv
    net stop cryptSvc
    net stop bits
    net stop msiserver
    ren C:\Windows\SoftwareDistribution SoftwareDistribution.old
    ren C:\Windows\System32\catroot2 catroot2.old
    net start wuauserv
    net start cryptSvc
    net start bits
    net start msiserver
    Retry Windows Update.
    1. Fix Admin Permissions
      Check Account Type:
    Go to Settings > Accounts > Your Info.
    Ensure your account is listed as Administrator. If not:
    Sign in with another admin account (if available).
    Enable the hidden admin account via Command Prompt (Admin):
    net user administrator /active:yes
    Reboot, log in as “Administrator,” and grant your main account admin rights.
    Take Ownership (for app installations):
    Right-click the app/file/folder > Properties > Security > Advanced.
    Change owner to your account, check “Replace owner on subcontainers,” and apply.
    1. Resolve App Installation Errors
      For Microsoft Store Apps:
    Run the Store Apps Troubleshooter (Settings > Update & Security > Troubleshoot).
    Reset the Microsoft Store:
    Open PowerShell (Admin) and run:
    Get-AppXPackage WindowsStore -AllUsers | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register “$($_.InstallLocation)\AppXManifest.xml”}
    For Non-Store Apps:
    Ensure you’re downloading the correct 64-bit version.
    Temporarily disable antivirus/firewall (may block installations).
    Run the installer as admin (right-click > Run as administrator).
    1. Check for BIOS Conflicts
      Please press delete key as soon as you turn on the PC, so that you can go to BIOS. Please send us a picture of the Main page.
      We will check if you need to update the BIOS.
    Update drivers manually via Device Manager (right-click Start menu > Device Manager > check for yellow warnings).
    1. Nuclear Option: Clean Windows Install
      If issues persist, perform a fresh Windows install to eliminate pre-installed bloatware or corruption:
    Create a bootable USB using Microsoft’s Media Creation Tool. Here is the tutorial https://url.bee-link.cn/74zu
    Backup data (if possible), then boot from USB and install Windows.
    1. Hardware Check
      Run CHKDSK (Command Prompt Admin: chkdsk /f /r).
    Test RAM with Windows Memory Diagnostic (search in Start menu).
