Hi,
I have received your email the other day with a download the latest BIOS file and tutorial for my Bee-Link GTi14 Ultra 185H mini PC. The filename is called: GTi4T204.zip, I extracted the files to a 32GB usb flash drive using FAT32. when I type the flash command at the prompt,I am getting the following error: when at the Shell> Prompt:
Shell>flash
fpt.efi -f GTi14T204.bin
– Flash Devices Found –
ID: 0xEF6019 Size: 32768KB (262144Kb)
Error 13: An unknown error occurred while opening the file.
FPT operation failed.
Shell> _
Do you have a solution for this?
Regards,
Brian
