Johson Hi, a while ago I remember there is above 4g decoding in the bios of gti12 and gti13 but now I can’t seem to find it in the bios. Please tell me where it is located. Thank you!
support1 Johson Hi there, it doesn’t have Above 4G decoding option in the BIOS, but you can go to BIOS–Advanced–System agent(SA) Configuration–VT-D setup menu–Above 4 GB MMIO BIOS Assignment, you can enable it , press F4 to save.
support1 Johson Hi there, after we check with our R&D, the option of above 4g decoding is hidden in the BIOS, but it is enabled by default.
