I recently bought a KVM from KCEVE to connect my two HP notebook and SER6 to share a monitor. All of the computers are attached via HDMI to KVM. From the KVM, it goes via HDMI to monitor via a DVI cable.
The issue I have is that SER6, when boot for the first time, will not show up on the monitor, even if I ensure that the KVM has been switch to the miniPC before boot up. I will need to power cycle the KVM in order for the display to show up. This does not happen to the notebook, regards if the KVM is switch to the notebook before or after booting.
I have changed the HDMI cables, I have changed the KVM ports, all to troubleshoot the issue. But it still points to the SER6 as not being able to detect or know that monitor exist.
After power cycle the KVM, and the display is good, I am able to switch to the other notebooks and back without any problem. It seems the problem only lies in the bootup, failure to display via HDMI into the monitor (my KVM has EDID feature as well).
I should point out that before the KVM, when I connect directly to the monitor, I do have a similar problem - where the display does not show up. As my monitor allows me to switch from DVI port to VGA port, I could cycle through those, and the SER6 will then show up. But now connected via the KVM, doing this via the monitor switch (toggle between DVI port and VGA port) does not work anymore.
My SER6 is SER6 PRO-E-32500EJ0W64PRO-DP. And its Serial Number is 7735H3FE10415.
Appreciate any advice. Thanks.
