Nemorino Hi,please send us a picture of SN on the bottom of the PC. May I know what’s the version had you updated for the machine?
Here are some solutions you could try:
②Please take out the RAM ,please clean the contacts of the RAM with a rubber. Here is the tutorial https://url.bee-link.cn/AzzB or https://mega.nz/file/7nwDmCaL#UyzSmVkqJG8HW9dhjHhLkkzdP9gt2Br3xyCG1SCdbrA
