FreckleEye servger @Beelink CS-Bony, We tried to do something similar to what you suggested, but with no luck.
Beelink CS-Bony FreckleEye I’m really sorry that this problem has bothered you for so long. The R&D personnel haven’t detected it yet. Thank you again for your patience in waiting.
Beelink CS-George Hi there, Update: Now we have newer BIOS , version FP656V508 ,it can solve the Platform KEY issue, here is the BIOS https://url.bee-link.cn/meRy, here is the tutorial https://url.bee-link.cn/VfJN . Any questions, please do let us know.
FreckleEye @Beelink CS-George, Thank you for the update. I’m following the tutorial provided, but when I get to flash.nsh enter. I receive the following error: 1d - Error: Failed to load image into memory.
Beelink CS-Bony FreckleEye May I ask if the USB flash drive has been formatted and if the BIOS file is placed in the root directory?
support11 Hello there, We will ask for thr technical personnel about that. After getting any reply, we will contact you. Or you could contact our emai:support-pc@bee-link.com
Beelink CS-George Hi there, please change the command AfuEfix64.efi FP656V508.bin /p /b /n /k /x /l /r /capsule to AfuEfix64.efi FP656V508.bin /p /b /n /k /x /l /r
FreckleEye I should have mentioned that I tried that command and it updated the BIOS, but still gives the same result as before.
Beelink CS-Bony FreckleEye Please provide screenshots of the current BIOS version and screenshots of PK FAIL. We’ll check it for you.
JohnO Has anyone confirmed that FP656V508 fixes the issue? I want to enable Secure Boot using a valid PK but the last message above indicated the new version wasn’t working for them. I’m hoping one of the folks who was having this issue before can confirm that FP656V508 fixes the problem and has a valid key before I go to the trouble of flashing it. Thanks, -John O.
Rahim Hi Everyone, I don’t have a specific need, but the BIOS update was successful. I tested it using the PKfail method from the following link, and it passed.
