DeanS
Don’t worry, the PC has one-year warranty. Please send us a picture of the purchase record. Here are some potential solutions:
⑤Update graphics driver: Please uninstall the graphic driver in the device manager and install the new one. Here is the driver source : https://url.bee-link.cn/mGVP
If these solutions don’t work, during the warranty period, we can apply for power silicone for you to solve this problem.
