What are pros or cons of each configuration?
In the case of Intel 1220P vs Ryzen 6600H, TDP is different → 28W vs 45W, which means the Intel is running cooler, but Ryzen makes up on this with better overall performance. I/O ports and casing/cooling look practically the same. Since they’re really closely priced, it’s hard to decide. 😅
What would you say is the biggest difference between the two?
And within the same platform, is it worth to upgrade to higher-grade CPU configurations?
    SLVR If the PC is only used for office work, 1220P is recommended, which is more stable.
