It doesn’t turn on anymore. I bought a new power supply and it didn’t work. I press the CLR CMOS and nothing happen. How can I fix it?
Regards
Could you please send us a picture of SN on the bottom of the PC and a picture of purchase record ?
First,please unplug the power supply and HDMI cable.Please hit the pinhole of “CLR CMOS” with a pin for about 10 seconds.Ten minutes later, plug the power supply and HDMI cable, turn on the PC again.
If the problem persists, please try other solutions:
1.Please take out the RAM ,please clean the contacts of the RAM with a rubber.
Here is the tutorial :https://mega.nz/file/XqZX0TIR#_DtO2oa4aRP4bWtvxgKLj4QGhBpQ959cg5U3Yw4u1Cc
2.Please change another HDMI cable.
3.There might be something wrong with the hard ware components.Please take out the SSD and RAM and then put them back , make sure they are installed properly.
Also please clean the gold finger with a rubber.Here is the tutorial:https://mega.nz/file/7nwDmCaL#UyzSmVkqJG8HW9dhjHhLkkzdP9gt2Br3xyCG1SCdbrA
If it still doesn’t work, please try to replace SSD and RAM or put the SSD or RAM to other devices to test if they work.
4.And pls try to take out one ram out, and then just leave one in the box to see if that machine could work, and the same way to test the other one , to see if that is ram issue.(if your ram is more than 8gb)
Please let us know what happens after you try these steps.
Have a nice day!
I am not bein able to upload the picture of the SN. Here is the number: 6800H3DG00176, SER PRO-E-32500EJ0W64PRO-V12
    When I have reset the BIOS with the pinhole switch I have had to wait a few minutes for the BIOS to wake up, so make sure you are waiting 10 minutes or so before you decide the device is not going to wake up and start taking it apart.
    Rhatori hello, thanks for your information, may I know is there anything worked? thanks
