• Supporters
  • How Can I Fix My Windows 10 “Automatic Repair” Error Myself?
I was using an i3 processor on Windows 10 when suddenly it shows the error “Automatic Repair.” The laptop repair shop is too far away, and I want to fix it myself at home. Do you have any ideas or step-by-step solutions to resolve this issue without needing professional help?
    Jamseung78 Hello there,
    Please send us a picture of the SN on the bottom of the PC.
    Do this twice
    Then start the Reset
    [unknown] Thanks for your sharing
