Could anyone please help with the above error?
It is persistent that every time I Login to Windows, the error message is registered in the event viewer log.
The description for Event ID 56 from source Application Popup cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
PCI
01000000684CE00000
Error Screenshot.
Device Manager - Everything seems to installed properly.
Thanks,
Andy
