S H SER 8 8745HS How do I enable XMP / DOCP in Bios? Is there even XMP/DOCP in this bios. I just upped my RAM from 24GB to 64GB and ran a test on user benchmark and it revealed that my RAM was slow for my build and suggests enabling XMP to bring up the RAM performance.
dltmchn S H SER8 8745HS support maximum 5600 MHz DDR5 SODIMM RAM. As far as I know, there is no XMP option in the BIOS, the motherboard doesn’t support overclocking.
S H I looked all over the bios and couldn’t find anything I was hoping there was something I had missed. Thanks
support7 S H Thank you for helping solve the user’s problem. Your response is correct. Have a nice day!
